Thanks all for your replies!
The prospect of getting a Turbo MR2 is tempting, but I can't afford one until I've finished paying off my University tuition fees as I am a self funded student, 9K is a lot of money to find each year
plus paying living costs and all that jazz.
But I reckon I can get this one roadworthy in a matter of weeks or months given the progress I have made on it. It is probably not worth turbo-charging this one, but at least if I drive this one and the engine goes, I have a myriad of engine conversion options, or I can sell it on and save for a Turbo MR2 or another RWD car.
I would like to fix this one up and enjoy it as these things are getting scrapped all the time and I reckon Turbo and NA versions will both gain value over time given the rate at which they are being scrapped for sill problems.
It's probably like comparing apples and oranges, but ever since I sold my RX8 and yellow Spitfire, I have missed RWD and this one drives so much better than my Corsa B does!
Today was quite a productive day:
(1) New Oil and filter change - no leak, that small oil puddle is where my sump missed the oil can when I was draining it.
(2) The broken mess of wires that attach to the Sidelights/Indicator/Front reflectors
(3) Fixed with a quick solder job and some heat-shrink. I later put insulating tape around them.
(4) Passenger side pop-up light motor found in boot along with some other bits, looks like the previous owner was going to fit this, but the bracket is all bent up, so I had to use the one on the car:
(5) All Front lights now working today after the quick solder job and replacing the motor.
(6) All rear lights now working as of the weekend (Brake and reverse lights also work, but a bit difficult with just one person to test!).
It's not been a terribly bad project so far.
I checked the tyres and only the passenger side front one is nearing the legal limit. I will replace the front two before the MoT.
Work left to do:
1). Bonnet Latch - missing a grommet I believe.
2). Front Trunk Latch - missing a clip I think.
3). Clean up calipers and discs, they seem quite clean, but I want to make sure the calipers are free before the MOT.
4). Front passenger reflector (may need to get a pair of lights though as I can't find these anywhere).
5). Check brake hoses - replace if necessary.
6). Weld hole in sill.
7). Put surrounds and covers back on front pop-up headlights.
8). New wiper blades. The window isn't being cleaned up properly with these ones, so new blades are needed before the MoT.
That should be all that is needed for the car to be MoT ready
