Thanks for your replies!
Spaceman - I agree - it is so much nicer without the scoops. I now have literally a boot full of spare parts to sell ha ha! I remember coming across that post after using a search engine - I have added it to favourites so I don't lose it!
Adam Cool Dude - I do like the 300ZX turbo wheels, some are finishing on eBay - but there is nothing about them being staggered, so I can't take the risk with such little time remaining. But they are nice - not too 'busy' - I think anything up to 5 spoke will look the part. I will set up a search alert on my phone so every time they come up I know about it!
Sigma - There is a B&M near me, I will try to have a look on Wednesday
It has been quite quick! I wanted to get it running as soon as possible - as the Corsa will be getting sold as soon as this one is roadworthy, can't wait to drive it round properly, I'll get some breakdown cover, just in case, but it's the only way I can actually identify any potential problems. As it's going to be my only car, it will be a running restoration as time goes on, no doubt I will have a whole more jobs to do to it!
The Running Man - those are really nice alloys - do you know who makes those? I had a look on the Rim Style web site but there is nothing quite like those on there!
*****Today's update******
So I got back about an hour and a bit ago from my garage; we had to run a long extension lead to a friends house, as I don't live near my garage and we got started.
I literally did none of the welding or cutting because I don't know how to! Apart from a few hiccups, the rusty panel has been removed.
(1) Here is how it looked when it was being taken off by a friend of mine:
When we took it off, the inner sill looked remarkably clean - I've been really lucky! It's not to say the rest of the inner sill will be as corrosion free, but it's a good start. I need to find a new set of straws for my Bilt Hamber cavity wax, I'll order some shortly - I want to make use of the grommet hole before I put the grommet back in and really fill the area with all my cavity wax to protect it at least for the next 3-5 years when I will need to probably replace the whole outer sill panel.
(2) This is the panel removed:
(3) This is the new panel in, with a skim of filler I have put in to just reduce the low/dented spots and imperfections on the patch:
I need to just smooth it over, prime it and then I will MoT it as is, I'll get the correct paint for it, but I want to make this nice and smooth first.
However I do have a few concerns before MoT:
(1) After doing an ECU reset, it looks like my idle is now at 1800 going down to 950 or so eventually. This is better than 2000, but still on the high side. I couldn't get at the ICV and might need to remove some of the intake system; so I am going to try again Wednesday.
(2) For the second time, whilst being parked on my hill and idling, the MR2 stalled out. This happened previously before the new fuel filter was put in and before the above ECU reset and was one of the reasons I replaced the fuel filter. This tells me that the fuel filter and the ECU reset have not resolved the problem and I am now looking at a fuel pump, or fuel pressure regulator issue, or both. I think Redex treatment for the injectors should clear any blockages and might resolve the problem - but running the old fuel filter may have already affected these and irreversibly damaged them, depending on how much the fuel inside the filter had lacquered. On the flat, it seems to idle with no issues. I don't like idling the vehicle for long periods, but it's the only way for the coolant to make a full heat cycle and for me to be able to check the cars functionality, check for leaks and niggling stalling problems on hills haha
(3) The car has had roughly 15 litres of fuel in it since I purchased it, but there is no way to tell with it how much is left and how long the car will run for - I need to get the fuel sender working or perhaps fill it to the brim once it is road worthy and has an MoT and see if this 'jogs' it.
If I can't resolve the fuelling issue before Friday, with the Redex treatment, then no MoT test for me
The petrol gauge issue I can live with a bit longer - I'll just stick another 5 Litre can of petrol in it which should be plenty enough for the MoT - provided I do resolve the high idle issue and the fuelling issue.
I am going to check the pressure of the fuel pump through the fuel pressure return pipe (once I find where it is!). It has been suggested to use a bucket to measure the litres a minute from a fuel pipe, but that doesn't seem terribly safe!
I may well be looking at a new pressure regulator, or a new fuel pump, or both. I am definitely not comfortable taking the car to any MoT station, regardless of how close it is until the fuelling issue is resolved because it could conk out anywhere and there are a lot of hills here! Whilst I have been able to get it going again and driven it up the ramp and in to my garage, after it has stalled, I don't have that privilege on roads with traffic on them! I could be looking at three figures to replace both the pump and regulator - but I'll have to wait and see after the Redex treatment. I have seen both of these parts for as little as £20 each on eBay, but I don't know how genuine or good they might be for that sort of money and will need to look around once I have got to the bottom of this problem.
My plan and intention is to drive the car to the MoT station, once I am satisfied with the fuelling. I haven't actually booked my MoT yet, as it depends on how Wednesday goes with my idle and fuelling issue. The idle might not be as much of a problem at the MoT test - perhaps the car just needs a good run once I have resolved the fuelling issue and got an MoT certificate!!
New longer to do list
(In no particular order).
(1). Smooth filler and prime it on repaired area.
(2). Redex treatment, fuel pressure test, possible fuel flow rate test, potential fuel hose replacement all round.
(3). Brake caliper rebuild all round, new hoses and new fluid.
(4). Replace/bypass hoses from hell.
(5). Remove foam.
(6). Source and install spare wheel cowling.
(7). Inspect suspension for any corrosion issues.
(8). Check for play on steering wheel and if within manufacturers recommendations.
(9). Check timing belt for any cracks or fraying and replace if necessary.
(10). Check engine, exhaust and gearbox mounts for any signs of wear or damage.
(11). New Tyres all round.
(12). ICV bench testing inside vehicle to check functionality.
(13). Check for air leaks with WD40 in case these are causing the high idle issue, replace any bad hoses.
(14). Check fuel sender functionality and fuel low light functionality, replace these units if necessary.
(15). Remove bumper and move the new horns to where the old horns currently are.
Phew, plenty still left to do!!
