Yip, runs very smooth and looks fantastic. Ive started on the DLC ("Sams Story") for the first time - good so far.
"VRS is a performance booster. 2x2 adjusts resolution in a 4pixel area while 4x4 does it in a 16 pixel area. So for best image quality set it to off."
VRS ON or OFF? :: Metro Exodus General Discussions (steamcommunity.com)
RTSS = RivaTuner Statistics Server (again if you even use it).
CRASHING ALL THE TIME :: Metro Exodus General Discussions (steamcommunity.com)
It crashing due to his unstable overclock and he refuses to remove it and blames the game
Yeah. But if i run this game at stock clocks i lose 7fps ! That is massive because i run the game 1440p. _- This need's to be fixed.
LMA0. This is the only game that crashes with any type of OC. dude pls. 7fps is huge when you play at high ress. go troll some place else.
RT pushes your system, including system RAM considerably harder than standard games. It could be that any overclock you have on your system RAM isn't stable being pushed so hard. I know of others here who had trouble with games crashing with RT turned on but after dialling back their RAM timings and/or frequency a bit, the problem was solved. Might be worth trying...What a technical disappointment.
I've played about 4hrs so far of a the Enhanced Edition but right now the game is crashing on me every 30 mins. Also seem to be in the same area.
Additionally the RTX effects are not that much of an improvement in my opinion.
