Middle Earth: Shadow of War
That's exactly what it is based on what I've read.
Ok thanks - do you know if you need SoM installed, or is it tied to steam cloud, or WB account? I'd quite like to free up that massive amount of disk space.
The only tangible info I can find on this exact point is
Important note: In order for Nemesis Forge to work, you need Shadow of Mordor and Shadow of War to be installed on the same platform.
To import your Nemesis and Follower into Shadow of War all you need to do is play Shadow of War on the same platform and with the same account you used for Shadow of Mordor. Shadow of War takes your most recent save from Shadow of Mordor and automatically imports the 2 orcs into your game.
But thats not clear to me if its sufficient to just start a new game in SoW, and my Orcs are already imported, so I can now uninstall SoM, or if I have to keep SoM on my disk. Curse my 256GB ssd!
Well I'm happy to say after 6 hours the game is great fun, very much the same as the first so far. Unlocked the second big area but have so much still to do in Minas Ithal which looks superb.
Just a small tip is you can put runes in your weapons to add extra % chance for any mob to drop ingame cash (the coin to buy crates) and every little helps. I've bought a few crates this way ( no real cash purchase ) and got a few nice legendary weapons and armour pieces.
Make sure dynamic FPS is turned off otherwise it auto changes resolution and it goes all blurry.
I have to play it at 2150*900 (.39x) to keep a healthy 50-60fps but it doesn't suffer visually that much.
k3EEVb
For some reason running this game is fine, but web browsing is quite a drag.. doesn't appear to do it on other games!
Ah possibly culprit, 97-100% cpu usage! yikes.
Use reshade. Looks so much better
Reshade Off :
Reshade On :
The compression in the upload doesnt really show the difference but in game its quite substantial.
Those of you with the 4k cinematics pack installed....are your shelob memories clips working correctly? The memories start to play bit then the audio clicks and they just send you straight back in to the game as if the clip had played through on mine.
Is it just me or does the game look worse than the first one, at the very least, it certainly doesn't look to have been improved graphically.....
