Just tell us the steps you made to unlock the card...
And there you have it people.
Its like i said don't give up.
Come on Krugga you can do it
Erm i think i need £200 fast for another card
Oh and dfgdfg i think you will be pleasantly surprised.
A few more people and we can start an msi twin frozr 3 overclocking thread![]()
Post your findings, I'm very interested in how efficient the other profile is.
It might not be of much use to me as I'm planning to overclock my card very soon anyway.
I give it a try, couldn't hear a difference to be honest, certainly not one that would make a difference over the rest of the fans in my case (especially the CPU fan). I turned off every fan in my case and it was pretty inaudible on performance mode tbh!Changing my CPU fan PWM to 37% min / 50C target temp did more to improve noise levels.
Erm the fact that you cant unlock your card makes me a moron does it?
No really come on do tell me why you think im a moron,
Is it because you will never have 1536 shaderswith your clapped out card.
Your just jealous dude and your starting on the wrong person.
Look at your 1408 shaders and tell me why i think you cry yourself to sleep every night![]()
Did you measure the noise at full gpu load?
Nope, probably should have but if your going to run it under full load the performance profile is probably the one you'd be using.
Really don't give a rats a** what you think tbh
I was trying to be positive for you and help you out but if that's the sort of negative feedback you give people when they try to help you then i feel sorry for you.
I make the mistake of assuming that everyone posting in this section is in the know, especially after they school me on what I'm doing wrong and then prove that they have no clue of what they're on about.
Sorry if I offended you.
My card appears to be from an unlockable batch, like many others and I'm not too fused about it but your successful unlock proved that there are a couple more successfully flashed cards from the recent purchases (mine comes from a different vendor so might be from a different batch as well).
Don't worry about your card being unlockable- mine unlocked, but is artifacting with the more shaders(without any OC/voltage change), so I am using it with the stock BIOS
Mines idling at around 37 degrees with fans at 50%.
I up the fans to 65 when gaming, but I have a headset on then so the noise doesn't bother me.
I'm assuming you're using MSi Afterburner and have configs loaded for different usages?
