been crashing all night again, fed up now its goin back.
will i be able to swap it in oc for a same priced nvidia card?
Have you tried turning it off and on again?
Seriously though, something is wrong with these cards. It's another MSI Radeon that I can't really be happy with![]()
have you tried it in a different slot?
i think i might have fixed it, just had bad company 2 running for 4 hours with no problems
installed 11.5 Cap4 without CCC
Tempted to download BC2 just to check if the game is really at fault.
Been running Civ5, Witcher 2, EVE and Crysis 2 all maxed out for days now with no faults whatsoever that weren't my own or ATI's crummy driver's fault. Really can't believe that an issue with hardware can cause only 1 game to malfunction.
To explain "ATI's crummy drivers":
Catalyst 11.4 Windows Experience Index 7.4 (a bit low yeh?) and two crashes.
Catalyst 11.5 Windows Experience Index 5.8 because it couldn't get through one run without at least 3 driver malfunctions in both DirectX9 and DirectX10 testing phases, 2D and 3D.
Both never got through a 3DMark Vantage to the end without locking up the PC.
Removed all trace of anything ATI/Catalyst from my PC and installed 11.5b and the card has been amazing ever since. I had a MSI 4890 before, I think upgrading from that one somehow ****ed up the drivers that I then re-installed for the new card. That's just theory tho.
Everything runs stable and way above reference 6950's at the moment tho. Wouldn't go bashing the card for being crap, would say ATI needs to QA their drivers better.
Quite happy with my two cards so far. Got them running well now but not overclocked. Will do that when I have more time. Battlefield runs great on my new monitor and I'm glad I bought them.
what did you do to get them running well, i thought i fixed it but then 2 days later i got another crash.
ok, I figured out why I cannot get a stable OC past 900- the max voltage I can apply is 1.15 even with the latest AB 2.2.0.beta3(there is space on the slider but no result), gpu-z 0.5.3 reports constant voltage of 1.200, GPU Caps says Max VDDC of 1.150, no matter how I change it Furmark 1.9.0 reports only up to 1.150
for those who missed my post shaders already unlocked
ok so iv tried
11.5 cap 4 with and without CCC
different slot
lowering the core speed / upping the voltage to 1.164 on stock
going to try
change dx setting in BC2 from auto to 11
other games have been stable since i changed a few things apart from bc2 still
