- 1 Apr 2004
- Copenhagen
So its supposed to boost to only 1740 but seems to be going over 2000?
Is that normal or an error?
With the lack of overclocking headroom on these cards and the sheer brute force power usage it's quite clear they pushed it a bit too close to the edge of stability to get this level of performance. Shipping with stability issues out of the box is unforgivable but unsurprising.This does seem to me that there was a lack of testing before these cards were released.
What could also be happening here is the lack of binning.
the 3080 cards released so far are not using binned dies - so unless the manufacturers do their own binning, they may be pushing the boost clock settings a bit high.
the other thing that can be an issue is igors lab said the GDDR6x modules run very very hot so need really good cooling, maybe some of these AIB cards just can't cool the Memory well enough.
People are complaining about MSI cards crashing and reviews show their cooling is worse than the Asus TUF - has anyone with a TUF has crashing?
running a +900 mem OC on my card and its fine, sits at about 70c with fans at 70%.the other thing that can be an issue is igors lab said the GDDR6x modules run very very hot so need really good cooling, maybe some of these AIB cards just can't cool the Memory well enough.
My MSI Ventus 2080 says it boosts to 1800, but GPU-Z shows it going to 1950.
The card is dodgy.
Send any dodgy Ventus cards to me, I will highly ensure they are "disposed" of.
3080 ventus OC, the 70c is just the card temp so not sure why that's bad, if I crank fans to 100% it runs in the 50s.what card and what software for measuring memory temperature? You made need to use an infrared thermometer to get an accurate reading unless the card has special sensors near or on the memory
It is normal, the 1740 MHz is a guaranteed boost speed. All Nvidia cards I've owned have boosted significantly higher.So its supposed to boost to only 1740 but seems to be going over 2000?
Worried about the X Trio now![]()
My original concern with the Ventus (and also the gaming x trio) is there's no real holes in the backplate apart from where the chip is whereas pretty much everyone else went with holes to allow air to flow through. Anyhow mine is arriving tomorrow so I guess I will be able to check it out myself.
I wanna order tommorow 3090 but worried about that issues. Should i risk? What brand to choose?
Because that's how Nvidia Boost works, its perfectly normal. Nvidia chips automatically clock higher than the stock specs by default to gain more performance, as long as certain temp and power limits are maintained. Limits and curves set by Nvidia and the manufacturers vbios.
What seems to be happening here is that Msi haven't tuned the vbios limits correctly, and its boosting to a point of instability. Hence manually downclocking the curve by 50Mhz is enough to keep stability and performance where its supposed to be. No doubt Msi will release a vbios update.
