Adz said:I think it looks really cool. It clearly wasn't intended to be "subtly sporty" or anything like that, it was intended to look outrageous which it pulls off really well.
Mad Pierre said:power output does seem a tad high. I know Craig adam's, that had a white clio that was running T/B. fully modded head, with standard bottom end, was making 216 bhp N/A. from a megane F7R-710 engine. He then sold it on to martin, so I'll take it you seen that. Most i've seen proven on turbo is 280ish bhp. not saying your will make that, you find out once it run in. also what gearbox are you using. a JC5 ?. you just be popping the diff-circlip. if your planning on using that with a JB3 box, and driving it hard.
Malachy said:drop a clio/r19/megane derv crank in a 1.8 and you have a 2l aswell![]()
MAXIBOY said:hi mate. yes i,m running a fully new but rebuilt JB5 with lsd
Xez said:Everyone seems to be missing the point here. Yeh it may not be to everyones taste but the amount of time and effort gone into it is what should really be judged.
yes sorry a JC5 that no longer has circlips as the LSD removes them. i think a rebuild is about 190 quid plus parts from bernie. he does everything from clios to skylines.Guybrush said:JB5? It's either a JB3 (from a 1.8 16V) or a JC5 (from a 2.0 16v). The JC5 will still pop the circlip if you put too much through it, it will just take more than the JB3.
Incidentally, how much did it cost you to get the box rebuilt (excluding the LSD)?
MAXIBOY said:yes sorry a JC5 that no longer has circlips as the LSD removes them. i think a rebuild is about 190 quid plus parts from bernie. he does everything from clios to skylines.
i,ll look for photos. think the gripper has a bolt fixing though like the 172Guybrush said:Do you have any photos of the diff retention that doesn't use the circlip?
Also you mention 'cps' as the gearbox refurbisher, who exactly are they?
