- 1 Feb 2009
Bru have you had any updates?
There is no 10 days time scale
ring them back up and say your policy gives a 7 day turn around from pickup and that you are requesting it to be wrote off
The only thing with wall mounting is that wall is a paper thin plasterboard type of thing, I wouldn't trust it with the weight of that set 51kg. Hopefully any replacement will be much lighter.
You need to find the beams in the wall. There's devices you can buy that can detect them for you to mount the wall bracket bolts.
Well I can believe you or go by the paper work in front of me, I think I'll go by the paper work thank you
The store is the keema masala one and the cover is any damage or fault for whatever reason. As it should be for £15.99 a month.
The set cost me £2499 nearly five years ago and at the time it was the top of the range set that LG did.
£15.99 x 12months x 5 years.......... nearly a grand........hmmm
Yep, but I don't drive my TV down the road where other TVs may crash in to itIts only money.
How much did you spend on your vehicle insurance over that period just in case the unfortunate happens?
Its only money.
Its only money.
Even with finding the support studs I still would want to hang that much weight on the wall.
