- 24 Sep 2007
The trick with motivation is making a start on something. Make starting easy. I find it helps using timers (get a watch with a stopwatch). So, set easy time goal for something you need to do:
10 mins working
then
3 mins break (e.g. watching YouTube video, don't let this overrun)
Repeat.
For the 10 mins "work", this is just something you need to do, targeted towards a goal. E.g. a chore around the house. Just remember, you only ever need to do 10 mins, then you can 3 min break. It works.
As for inspiration about hobbies etc, I advise making a list, so whenever inspiration strikes, write it down. In general it's good also to have notebooks around to write notes when ideas pop into your head, e.g. inspiration, goals etc. Then prioritise the list so you know what you want to do first. Then set small goals and put them into your 10 min / 3 min routine. The trick with motivation is setting very small targets just to get you started, then once you have started, you keep going.
Hope this helps.
10 mins working
then
Repeat.
Hope this helps.
