ok...i took the plunge and popped into OCUK and picked up a NEC.
One thing first off, the box they got out was taped twice and had a 1 by 2cm tear in the corner...so I tell the chap, is that one that has been returned? He says: 'No it couldn't possibly be. The boxes go really quickly and it wouldn't be in this condition.'
So after the suspect look I take it away.
Get home after 35mins drive and open it up! First bad sign, the analog cable had been used. Also you know when you look at something and you get that 'this doesn't look right' feeling.
Maybe I'm paranoid after my mate getting a 2005FPW from OCUK that had cables attached to monitor! This felt opened before. The unit itself was pristine, couldn't see anything on the screen itself.
Anyway, I let it settle for 20mins and hook it up. On she goes...quick check on white then black background...no dead pixels...gotta run pixel buddy yet. But all seems good. phew.
However, yes you guessed it...I got backlight bleed... Bottom right corner it perfect, so much so that it could pass as a black hole, the black is so deep.
The lower left corner has it pretty bad though. If you imagine splitting the whole screen with a horizontal line and vertical line in its centre, then the lower left quadrant is about half affected accross the diagonal from the corner...if that makes any sense!
Can't see it anywhere else, need a completely dark room to appreciate it, so I'll report again later at night. Also that will allow some time to bed in...fingers crossed it goes away!
If not will await what NEC says but if they can fix them then it has to be RMA'd.
On a plus note though, boy is this monitor good! I have seen no LCD like this. The richness of colour and depth of black...wow. Also very very sharp, I understand the comment regarding it would pass as a CRT. The black as I said, on the areas that are perfect is so deep.
So, in summary, monitor is great. Backlight is poo but no dead pixels here. Let's give it a chance to settle for a couple of days and see about the backlight. The reflective screen is only a prob on very dark images. The sun is glazing through the window today, who would have said one would ask for no sun! I use the PC 90% at night and in a dark environment so it'll be fine.
Just thought I'd pass on my thoughts. Hope it helps someone! Great LCD!
Has anyone else had issues with receiving returned goods from OCUK? Out of interest only.
