I've heard reports here & there, but not on the epidemic level. For now, I guess that only solution is that (if it's really annoying) you don't use the standby function and just power off the monitor (via front illuminated button) after each usage session. Not sure that you can fix this by yourself.t_aitch said:I just went out into town, and got back a second ago and the monitor was in standby and making a really highpitch noise that would drive dogs crazy.
Thought it might have been the speakers or one of my fans being funny, but they were fine, it was coming straight from the monitor
Anyone had the same problem?
I noticed from your previous posts, that you have only 1 year guarantee ?! Why is that ? Are you sure that you didn't purchased the RMA monitor (from your e-tailer) ? How was the monitor packaging ? As you may see, I'm slightly worried that your monitor was already returned.
Anyhow, you may swap the monitor with NEC (if the issue is unbearable) and ask them why is that happening. I think that no one, from the affected users, didn't report back proper explanation.
You are not paying for any shipping across. From the user reports, it's very straight forward process.
... no carpets, wooden floor, wooden blinds. In essence, nothing is there to absorb the noise.
but the box was sealed every thing was init.
