DCat said:
- In certain modes there is a high-pitched noise coming from the monitor. I'll bet there's already on post on this but this thread is soooooooo long now
that its going to take me a while to find out
I do remember that someone mentioned that, but I don't remember if this issue is "resolvable", what's nature of this and if you should worry or not
Maybe best option is to search this thread for high pitched noise keywords
DCat said:
- After coming from a 17" CRT (6 years old and not exactly top of the range) I was expecting movies to look better on this piece of kit than they did on the CRT ... looks like I was wrong there. Movies are more blocky/pixelated/blurred.
It's normal. Especially if you are coming from CRT grounds. I was equally shocked when I migrated to LCD TV from CRT TV, long ago. Fortunately, you don't watch the movies from close (TV) proximity and my advice would be the same for LCD monitors: step back when watching the movies
Also, particular LCD TV sets are slightly masking such effects, because of the picture processing engine dedicated for such task. All LCD panels, especially monitors, are exhibiting such effects. Some more, some less but nothing substantionally different. NEC does have probably slighty more noise, especially because it's exceptionally fast panel, but when watched from proper distance - noise is starting to fade away. In my opionion, other factors like exemplary PQ, colours, Advanced DV modes, high brightness are also important for the movie playback and there is no lack of such things with NEC
DCat said:
Will try to capture some screen shots tonight and post them up to show what I'm talking about.
Good.
DCat said:
I have a HIS 512 1900XT so I'm pretty sure if there's a weak link it isn't the card.
No, video card is not the cause. I'm not sure what type of movies are you playing, however you have to be aware that video source quality (especially encoding quality and bitrate for DivX) and software player itself can damage the video quality and LCD monitor can easily expose this. Additionaly, some good codecs are offering the noise removal filters. Latest Catalyst & Forceware drivers from ATI & Nvidia are also focusing more on video features and they are including the video de-blocking and noise removal filters ... so after proper tweaking you may have interesting results with LCD panels and possible improvement in playback quality.
You may try to download WMV HD content and see how it goes:
http://www.microsoft.com/windows/windowsmedia/musicandvideo/hdvideo/contentshowcase.aspx
Also, you may try to play some uncompressed HD transport streams:
(HDTVpump is very nice DirectShow filter too):
http://www.dvbportal.de/projects/hdtvpump/index.html
