Can one of you guys do me a favour please... I have a dual core Core 2 Duo overclocked at 3.2Ghz. Game runs ok, but I see frame rate drops to around 30fps or sometimes less.. Can someone with a quad core (preferrably the core 2 quad generation) clocked around 3Ghz, go into the affinity of the .exe and just set it to say core0 and core1 (removing affinity from core2 & core3) and tell me what performance is like compared to having affinity on all 4 cores... ?
I just need to know if its a cpu or gpu limitation I have or maybe a game issue.
I'm running graphics at 1920x1200 , high res textures, af on and motion blur on. Even if i drop resolution to say 1440x900 and take off high res textures, af and motion blur it makes hardly any difference hence i suspect cpu limits.
Thanks,
Right I've just done this
I have a Q6600 at 3.0GHz.
I drove one of the time trial preview races where it was raining and recorded the fps with fraps.
All 4 cores:
Frames, Time (ms), Min, Max, Avg
6045, 102022, 44, 62, 59.252
Just cores 0 and 1 (2 and 3 disabled):
6043, 102803, 32, 62, 58.782
Subjectively it didn't seem any different with just two cores, even though the minimum framerate was recorded lower.
If there is a particularly demanding race in the career mode where your framerate slows down badly, tell me which one and I'll try it on my system if you like.
