16 Apr 2017 at 13:02 #41 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 It's this P8Z77-V LX BIOS 2501 - the top one, version 2501.
16 Apr 2017 at 13:06 #42 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 Then, ideally, install the unzipped file onto a freshly formatted (fat 32) usb drive.
16 Apr 2017 at 13:06 #43 NathanL NathanL Associate OP Joined 13 Apr 2017 Posts 804 My version is 1201 I'll just format a USB now
16 Apr 2017 at 13:11 #44 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 Nathan Long said: My version is 1201 Click to expand... Do you mean your current version is 1201 - or the one you've downloaded? You probably mean the former - but i'm just clarifying as it's easy to get lost in translation using forums..
16 Apr 2017 at 13:11 #45 NathanL NathanL Associate OP Joined 13 Apr 2017 Posts 804 Formatted it, and the unzipped file is on the stick
16 Apr 2017 at 13:12 #46 NathanL NathanL Associate OP Joined 13 Apr 2017 Posts 804 Yep, looking at the photos i took, my version is currently 1201
16 Apr 2017 at 13:12 #47 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 Great - yonly need to copy/cut the .CAP file onto the drive.
16 Apr 2017 at 13:13 #48 NathanL NathanL Associate OP Joined 13 Apr 2017 Posts 804 Yep, that's all that's on the stick, the .CAP file
16 Apr 2017 at 13:15 #49 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 If you've done that plug it in - and get into the BIOS.
16 Apr 2017 at 13:15 #50 NathanL NathanL Associate OP Joined 13 Apr 2017 Posts 804 Okay, i'll switch to forums on my phone so I can see what's going on.
16 Apr 2017 at 13:17 #51 NathanL NathanL Associate OP Joined 13 Apr 2017 Posts 804 Okay, currently in BIOS EZ mode
16 Apr 2017 at 13:17 #52 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 Alternatively, you can get to the BIOS and then stick in the drive - your choice (presuming you haven't got boot from USB).
16 Apr 2017 at 13:17 #53 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 Nathan Long said: Okay, currently in BIOS EZ mode Click to expand... Great
16 Apr 2017 at 13:19 #54 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 You need to get to the EZ Flash 2 utility Select 'Advanced Mode' and select the 'Tool' menu and select' Asus EZ Flash Utility' - by pressing Enter. (Are you ok using the arrow keys, tab etc?)
16 Apr 2017 at 13:20 #55 NathanL NathanL Associate OP Joined 13 Apr 2017 Posts 804 Okay, on that now, I can see the new .cap file. An I selecting that?
16 Apr 2017 at 13:22 #56 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 Yep, select the drive field and the then the file.
16 Apr 2017 at 13:23 #57 NathanL NathanL Associate OP Joined 13 Apr 2017 Posts 804 It says it's processing now
16 Apr 2017 at 13:23 #58 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 Then press enter to perform flash - it will probably give you a warning and ask you to conform your choice.
16 Apr 2017 at 13:23 #59 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,529 Nathan Long said: It says it's processing now Click to expand... Hehe...
