yes i looked and there isn't one
just google it, i purchased one ages ago.
that's it can't resist any longer.
The built-in conversion whih you would be using for films gives a very weak depth effect. It works better in some titles and scenes than others - you aren't doing anything wrong don't worry. Glad you notice the smoothness, but that doesn't surprise me since you came from a PVA .
Been playing with my new S23A750D for a few days, and absolutely love it so far. Input lag feels to be below any TN panel I've used and has had no effect on my ability in osu or twitch fps games compared to the trinitron CRT it replaced.
The glossy finish is just right - just like a CRT rather than a typical overly glossy LCD. The perfect compromise.
3D is pretty good, though the built in 3d processing gives a fairly underwhelming effect. Software depth setting more than makes up for this though and I can't fault the 3D in terms of ghosting etc.
Colours are really good, pretty much IPS in quality (but not accuracy of course)
My only complaint is the monitor is too bright - even at 0 brightness and 0 contrast (gamma mode 3, colour warm 1, magic stuff off) it is still too bright for my eyes in 2D mode, so I've been forced to reduce it in my graphics driver settings.
Bottom line is this is definitely the best CRT replacement LCD on the market where gaming is the primary concern.
Just want to be clear, does the 23inch model come with the DP cable included? If it does, how long is it?
Found these (StarTech), if i decide to purchase the 23750d i will give some feedback.You can buy an adaptor or a mini DP to DP cable (both will work just as well) for not a lot. Look out for companies such as StarTech who have some decent ones on some very large etailer websites.
Yes and I'd estimate about 1.5m
Thanks!! 1.5m is a bit short tbh, might have to buy a longer one.
On another thread here people were mentioning about new models coming out, but since these Samsung models have only just been released am I right in thinking that their will be nothing better for 6 months or more?
I really would like to read some indepth reviews from people who know more than me about the different types of panels to see how it compares to IPS because I have never seen such a good looking TN panel as this.
