Sorry, really busy ATM, I'll do it once if I manage to get the work finished. Hopefully .
Ah no problems I've been out all night anyways.
Thanks though
Can you remove the stand on the 950d? ta
you send it back, then they refund you. If shipping is an issue, I suggest you call them and ask they collect it/exchange it
They did a price match for my graphics cards. might be worth asking
Nope they wont do a price match as it was a 'this week only' offer even though it was in pre order status for most of that week...
I've priced up all my parts for new build and monitor and it works out quite a bit cheaper from a competitor so I think I will be going with them.
I asked in the CS secion. 5UB said they'd do it
Nice review PCM2, I'll link to it in case you don't want to self plug.
The extremely low input lag is great to hear about. With regards to the colour calibration, do you think it will be tough to get a good result without a colorimeter?
I was told no via the webnote system. Hmm :|
It still will work out cheaper for me to order all my parts from a competitor anyway I think, I am saving about £150 I could put that to good use elsewhere!
£150
ask for a price match for all of it?
Great review PCM.
Good reading and I can argue with anything there.
I am loving the Monitor and was pretty sure it was a good one.
I kiss my monitor everynight before I go to sleep.
Can someone tell me if I want to use display port, does a cable for this come with this monitor, or, what sort of cable do I need to buy ?
