23 Oct 2011 at 12:49 #1,141 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland yeah I realised after I looked at them what about the 950d?
23 Oct 2011 at 12:50 #1,142 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon same goes for them all
23 Oct 2011 at 12:51 #1,143 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland your motherboard has dp on it right? can't you use lucid virtu for the other displayport?
23 Oct 2011 at 12:51 #1,144 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon wha wha wha?????
23 Oct 2011 at 12:53 #1,145 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland you know the power saving thing that is in all z68 motherboards?
23 Oct 2011 at 12:53 #1,146 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon no??? would it work with gaming though?
23 Oct 2011 at 12:54 #1,147 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland it's supposed to try it, your 950d has dp too
23 Oct 2011 at 12:55 #1,148 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon I will. but can't due to lack of room on my desk doh! Also need a DP cable
23 Oct 2011 at 12:57 #1,149 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland if it does, then you can swap the 950d for a 750d and solve your problem
23 Oct 2011 at 12:57 #1,150 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon yes... if it works....
23 Oct 2011 at 13:12 #1,151 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland why don't you try the 950d through the dvi port on your motherboard then? if that works then the dp should do the same
23 Oct 2011 at 13:13 #1,152 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon KiiYzOo said: why don't you try the 950d through the dvi port on your motherboard then? if that works then the dp should do the same Click to expand... don't want to take the chance TBH
23 Oct 2011 at 13:15 #1,153 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland did you get a dp cable with your 750d's?
23 Oct 2011 at 13:15 #1,154 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon yes, but not with the 950 I'll order one now. Just tocheck, it is male to male right? (lol, male to male)
23 Oct 2011 at 13:17 #1,155 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland yeah do you have a hdmi cable? you must order an ocuk mug too
23 Oct 2011 at 13:18 #1,156 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon KiiYzOo said: yeah do you have a hdmi cable? yes you must order an ocuk mug too Click to expand... ofcourse
23 Oct 2011 at 13:19 #1,157 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland try a dp cable in your 950d and a hdmi cable in a 750d my ssd and ocuk mug are coming tomorrow
23 Oct 2011 at 13:21 #1,158 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon KiiYzOo said: try a dp cable in your 950d and a hdmi cable in a 750d Click to expand... But that won't determin whether I can have 3 DP Also, try to keep this thread on topic
23 Oct 2011 at 13:23 #1,159 KiiYzOo KiiYzOo Soldato Joined 2 Jan 2011 Posts 6,150 Location Edinburgh, Scotland it will not make a difference as to whether you can use dp or not
23 Oct 2011 at 13:24 #1,160 Cleeecooo Cleeecooo Soldato Joined 8 Oct 2010 Posts 22,382 Location Purley - Croydon Are you 100% certain??? Really can't take a chance on this
