** NEW SAMSUNG 750D & 950D True 120Hz LED Monitors - PRE-ORDER! **
why would it make a difference at all? try it with a hdmi cable in one of your 750d's first, if it works then you can decide whether you should try it with a three dp cables to be 100% certain, or to just return your 950d and get another 750d
I guess. I'll have to order another DP cable anyway so might aswell do it now. Do OcUK have to receive the monitor back within 7 days for the DSR to be allowed?
Under the Distance Selling Regulations (2000) you have the right to cancel the contract relating to your order at any time up to the end of 7 working days after the goods are delivered. To exercise your right of cancellation, you must give written notice to Overclockers UK by letter, fax or RMA WebNote giving details of the goods ordered and date received. Notification by phone is not acceptable. If you exercise your right of cancellation under the Distance Selling Regulations (2000) after the goods have been delivered to you, you will be responsible for returning the goods to Overclockers UK at your own cost. The Distance Selling Regulations (2000) places a duty on you to take reasonable care of the goods once you have exercised your right to cancel. Returned items must be packaged properly and shipped in a plain outer box. Please try to include all internal packaging, cables, manuals, drivers and protective bags, however small. Overclockers UK will refund you within 30 days for any sum that has been paid by you or debited from your credit or debit card for the goods. If after exercising your right under the Distance Selling Regulations (2000) you do not return the goods as required, Overclockers UK may charge you a sum not exceeding the direct costs of recovering the goods. When exercising your right to cancel under the Distance Selling Regulations (2000) please return goods to Overclockers UK (Esnet Ltd), 4 Axis, Millenium way, High Carr Business Park, Newcastle-under-lyme, ST5 7UF.
Yes. Preempting your questions, the 23 inch Samsung models should be a bit better in terms of responsiveness and colour reproduction once tweaked. The ASUS is a really decent screen too but not quite up to the hypothetical level of the Samsungs. The ColorShine screen surface is very similar to the Dell TrueLife and is more reflective than the Samsung Ultra Clear as illustrated in the T27A950 review comparison.
Finally got the 950D, and loving it so far!! :D
I even got the 2 pin plug, which was nice!
Havnt quite got 3D sorted out yet though...It doest seem very 3D...unless im doing something wrong lol
have you turned the depth to 10?
Pretty good in monty python life of brian (on iPlayer)
If you are viewing 2d content with the built I'm 2d to 3d converter it won't seem very 3d. If you are then you need to install the tridef 3d game launcher that came with the monitor and load one of your favourite games through that.
Then be amazed :)
Downloading some 3d videos would also be a good idea, most downloadable 3d movies come I'm SBS format so just play it in any media player and select side by.side from the monitors 3d menu.
Then be amazed :)
So are you saying that to get the best 3D effect with movies you should play/download 3D movies and set the monitor to side by side setting??
Yes, 100%.
2D to 3D conversion is a cool little feature, but its ultimately just a gimmick. Its not real 3D, not even close. It can be fun to play around with though with your 2D content.
If you want to watch movies in 3D then definitely download 3D movies (seems obvious, no? :p).
Not all 3D monitors allow you to choose which 3D mode to run from the menu, so you can download a program which does the side by side conversion for you (stereoscopic player, powerdvd 10, etc) and then just enable 3D on the monitor.
These Samsungs allow you to just choose it from the built in 3D menu, making it much easier as you can play the SBS movies in any player you like :)
Just tried CSS using Tridef.
AMAZING!!!!
However, it did feel a little uncomfortable. You know that feeling you get in your stomach when you fall from a height? Imagine that in your eyes...
