Do mammoth cases like the 900D come with 2 PSU support, or do you have to bodge it?
The 900D comes with 2 PSU support. You still need to buy a special cable to link the two PSUs though.
If you want the Ultimate case get a Caselabs.
I was looking at the Merlin ST10 the other day. Looks like an awesome case
Kaap, what loop are going with and pump for this beast? Single or dual D5? I'm thinking of going dual D5 dual bay res for mine.
I use these in my three watercooled setups
http://www.overclockers.co.uk/showproduct.php?prodid=WC-163-XS&groupid=962&catid=2141
What speed are your pumps set to?
My hearing is not very sensitive so I have them on max (5).
Having said that in a system with high flow rates like my GTX 690 system where all it has to do is cool the CPU, this maybe is a mistake. The reason I say this is the pumps really thrash the water around the system and aerate it which in turn I suspect can lead to things growing and discolouring the tubing.
The Little Devil cases are nice with room for 3 x 480mm rads plus some smaller ones.
Yeah there ok but you have increased ambient heat because of there design.
What ambient heat, my LD V8 system runs only two or three degrees above room temp on the GPUs.![]()
Tri SLI Titans are quite happy to run on a single Corsair 1200i PSU, unfortunately 3 x 290Xs had no problem bringing the same PSU to it's knees.
I will probably run two cards off of each PSU.
I will be starting one when I get going.![]()
Superflower 1200w 3 x 290x (1200\1600) and 6.2 CPU fine!!! Corsair need to bring back the AX in its none digital form.
There is more Ambient heat in the LD more than the Caselabs because of the separation of radiators. Thats got nothing to do with your personal temps. Also you can put 3 psus in it all completely hidden from view like behind the mobo tray and in the pedestal and more importantly in parts of the case where heat is kept to a minimum. Its a nice case but there are better cases in my opinion. Its very bland looking case for one, but again that is my opinion, just like your opinion favours the LD.
The 900D spanks it in my opinion for looks and also what its capable of especially for the price. The LD your just paying for the name. Aslong as YOU are happy with it, then it dont matter.
