- 13 Oct 2011
- Melbourne, Australia
I recently got this cooler for my birthday and just wanted to share with you people some of my findings, also a little help with my overclocking.
I am in love with the D14; i upgraded from an old H50 (push/pull SP120's) .
Before:
After:
The temps are so much better, had it running at 4.4 on the H50 though the temps were a bit high.
The D14 has no problems with it.
Nearly 15C less.. Crazy.
And i went higher
4.5Ghz
4.6Ghz
Just playing around with my OC settings at the moment.
Apart from 4.6Ghz, All the rest were tested for around 4 hours each, the 15 minutes bursts you see ae just to show you the top temps, as i found the top temp was normally reached in the first 15 minutes of testing.
What do you all think? On your way out to buy a D14 yet?
Before:
After:
And i went higher
4.5Ghz
4.6Ghz
