Caporegime
so you bought it early when the prices were still high? even worse then
Compared to Nehalem?
Medium settings/no AA
Also I moved from i5 2500k to i7 3770k and noticed no such bump in minimum FPS.
I don't have the time to police it - I have too much VRAM scaring to pour water on .
Indeed.
Psychodil: this is why the review is half decent it's no more than that. I don't see it any better than any of the other reviews. It's just more recent and the only one.
With a proper memory overclock I think the results would fall in line with what previous observations have shown.
I don't think you can take anything from the review really with that level of overclock. Like Matt said it might not have gone that high that still doesn't detract from the point.
What the review shows is at those settings they're level. It isn't really intellectually acceptable as an argument to generalise from that - with the memory overclock issue there - that the cards are truly level.
^^ Good info, thankyou.
It should also be said that while they seemed to have a less than average overclock on the memory of the 670 in that review, the core clock they achieved was probably above average.
At least it should hopefully put to bed the thoughts that BF3 performs much better on nvidia cards.
I know you haven't said it outright but they don't offset each other. My point is that because of the low memory overclock we're now effectively guessing what it would be like with a better memory overclock as we don't have the data to be sure. Which is why I post everytime somebody uses this review without the appropriate caveats .
Indeed. I think overall 12.8 has now all but closed the gap.
It's a shame it took them until now to really get the performance out the 7*** series that it offers but nonetheless still a good thing.
So you will agree the GTX 670's and 7950's are in the same performance bracket as eachother, this includes BF3.
I think that's blindingly obvious? If you had read my posts rather than ignoring the stuff about, you know, graphics cards you would have seen I had been saying that all along .
To a larger extent, the 7950, 7970, 670 and 680 are all in the same performance bracket while at a high level of overclock.
At a guess I would say slowest (7950) to fastest (7970/680) is no more than about 10-15% depending on the game.
Perhaps they used low memory overclocks on the 670 so that the GALAXY 660 would look more competitive in comparison. The side effect being that the 7950 was shown more favourably against the 670. I dont think they cared as the review was clearly just to plug Galaxy's name as much as possible
I don't think anyone is disputing that Tommy.
What is being questioned is the use of this as evidence of '7950 = 670' when the memory overclock achieved was poor in comparison to what other users are getting whereas 1.2 Ghz on the 7950 can't be considered poor. I'm not saying it can't go higher, I'm just saying there is well over 1 Ghz difference between the 660Ti memory and the 670 memory.
At those clocks shown the cards are about as equal as you can get. But the problem of using taking one review as gospel is that you can't balance out the overclocking lottery somewhat. One duff memory clocker effectively throws the results out.
Its a conspiracy..... can i take pleasure in that to? please?
Well overall that review showed the 7950 having a very slight average lead over the 670 at the clocks tested. With an appropriate overclock on the memory on the 670, we can assume the performance gap is either reduced, or it will slightly overtake the 7950. Either way they will be within a few % of each other on average.
