Hi! Couple of questions:
1) Do you have a price for Infinity version yet?
2)When will it be available for pre-order?
1. £299.99
2. Next Friday 12:01
Will it actually be available that soon? When would you anticipate these being in customer's hands?
1. £299.99
2. Next Friday 12:01![]()
So they're cheaper than the non-infinity version listed on the site? Is there a reason for that!?
Would also like tour advice.
I have the 980 HOF pre-ordered with you guys. I'm not sure whether to stick with the HOF, change for a 980 Classified, or get two 970 infinitys.
What would you recommend?
Which is the none-infinity version you are referring too?
The one this thread is about - http://www.overclockers.co.uk/showproduct.php?prodid=GX-205-OK
I think I've worked out why, is it because the infinity isn't using the Nvidia cooler by any chance?
Yes correct, that one is a NVIDIA reference card with their very expensive cooler.
Ours is our own design and even though it is expensive it has not cost us as much as NVIDIA reference cooler.
Ok, gotcha. If I'm planning to SLI I take it your reference version 970 would be the best option?
Would you recommend going with two of your reference 970s over the 980 HOF or Classified?
arrived today
changed delivery last minute as i was held up at the opticians, redirected to my neighbor, collected, job done, +1 for DPD
dunno about games yet, happy enough with the visualiser
really happy with this model of 970
arrived today![]()
+1... it looks lonelyLooks lush m8, needs a partner in crime though to be complete![]()
Are we likely to see any deals on the MSI 970 GTX this side of christmas?
hi, are these in limited supply? i need to wait until after xmas to buy 2.
also will you be stocking these nvidia sli bridges
