Looks like you may have the pick of the bunch there.
Also purchased the 4.6G kit (L318B359) happily runs 4.6 at 1.305 volts under load but my temperatures are peaking at 72c almost 20 degrees more than yours!
Using the OCUK V8 watercooling kit 240 rad with the D5 XSPC reservoir, rad and pipes are barely warm.
Using Gigabyte Z87x OC I had an issue with the cpu retention clip in one place actually being higher than the cpu, noticed it when i tried to reseat the block and found witness marks of contact on the XSPC raystorm copper plate.
Bringing the good old credit card in to play and laying the edge across the cpu and sliding it around i could feel it making contact with the retention bracket in one area.
Piccie
After removing the clip and taking a very small file to it and removing the high points until no more contact was felt using the cc it lowered my cpu temps from 84 to 72c.
Cant help but wish i had your chip !
Piccie
