And as for proper using a proper water cooling , I was using one for many years then one day it sprung a leak, and it went downhill from there, ie fittings going loose in hard to reach places, ye si did tighten it up first lol, then my d5 pump playing up. bay res leaking which no way no how i could stop. and had no replacement. i couldnt see water flowing via the bay res, ie the spin part was not moving. basicly everything that went wrong did go wrong. it was lucky i had a h100i here for my sons build, i used that stripped out the watercooling gear through it accros the floor, it took me ages to save up for the watercooling loop bit by bit i had a semi decent loop. i do not work so aquaring my pc parts take an age to save for hense going from my presnet spec to a new one, which im hopping will last a few years.
i have seen the monsoon fittings which seem to fit a lot better than others is that true. i have my radiator boxed up im sure there is somthing wrong with my pump so i would need a new pump and a new res, that res at the time cost me £60 was a waste of money, i got it as i thought it woudl be better getting one fo those so it woudl be easier to fit than putting holes in my new coolermaster case.
Anyhow the watercooling spec was.
rad was a Hardware Labs Black ICE Radiator GT Xtreme 360,
res was a EK-BAY SPIN Reservoir CSQ - Acetal, pump was a D5 Vario,cpu block was a EK Water Blocks EK-Supremacy, pump top was(first tried Bitspower D5 Mod Top V2 Extreme, Acryl Version, with the Bitspower mod kit, then i thought it was that causing problems then i went to a ek EK-D5 X-TOP CSQ - Acetal)
anyhow the price of liquid nowadays to fill a loop, ye si knwo you can use jsut distilled water ect, the truth be known i jsut cant afford to replace the parts in my watercooling setup, and if im honest i would be woried about using one now, leaks ect ect. i lost one motherboard due to it, i cant afford to replace stuff easily now
