OcUK Ryzen 5 9600X and Ryzen 7 9700X review thread
TPU did although you have to scroll down:
Woah a 6W reduction! Better tell my banker/accountant/investment person to expect another £10 a year.
Still lacking behind intel in that department , oh well maybe zen 6
Well that's disappointing. Overpriced and barely any better performance than the 7000 series. I hope the X3d cpu's offer more or I will just pick up a 7800X3d if the rumored price drops happen.
Total noob question: what’s the interplay between ‘eco mode’ + ‘PBO’ with these chips?
Presumably if a chip is on ECO mode with a fixed wattage, PBO ceases to function?
Also, not sure there has been any eco benchmarks test with the new chips but perhaps that’s because it’s pointless…? I recall there being a lot of positivity about eco modes on the 7000 series.
Again, noob comments :)
Those 30-40% less power computation numbers in Cinebench was in the R23 release, Anandtech tested the Cinebench 2024 version and found not much difference in power wattage. Is the Cinebench 2024 more accurate or just different no idea.
Anandtech
Looking at how the AMD Ryzen 7 9700X compares to the previous Ryzen 7 7700, we can see both perform similarly regarding power consumption. Both chips, when loaded up with the Cinebench 2024 multi-threaded test, consistently tread between 88 W (9700X) and 90 W (7700).
Just looking at the other reviews on YT, so just a bit weird seeing many reviewers discussing how much lower wattage the 9700x is but then others suggesting the 7700x is similar.
You said Intel are still ahead of AMD in power idle power consumption which they aren’t. You’d have to back to Skylake for that to be true
Ok fair should have been
which has lower idle , 14th / 13th 13600-13900 / 14600/14900 or Ryzen 5/ 7 / 9 7xxx / 9xxx
