Well can't solve the issues so had to take the plunge and buy new mobo and cpu, just a quick question if anyone has a Corsair HX 620w PSu and an Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard am I going to need any cable extensions for the PSU, would like to get these before the mobo arrives so I can build and not have to hang around too long chasing cable bits.
Thanks.
I had to use an extension, see here
http://forums.overclockers.co.uk/showpost.php?p=10130713&postcount=7
probably because I put the psu in upside down.
Any idea if I can get one of those extensions from OCUK for my Hiper type-r?
The cable was so short on mine that I had to install the PSU upside down, and even then it was at a stretch.
nice mod there marcus
2. I bought an Asus DRW-2014L1T 20x DVD±RW SATA Dual Layer Lightscribe ReWriter from OCUK of course (typical it's on 1 week special now) when I tried t fit it into the P182's 5.25 driave bays with the rails it stands proud by about 10mm when the rail is in the locking slot, I have the drive on the last set of holes possible there's no way I can get it any closer to the back of the drive, anyone had this before?
Hope one of you can help,
Martin
So whats the best way of mounting a PSU? Fan facing downwards or upwards? (120mm fan PSU).
