I managed to fit all 4 that came with the Corsair, the P182 has enough holes to make it possible to mount the PSU either way up.
Post pics...do hate links.
Hmm... weird, your cases don't have the performated back mine does!
) when I tried t fit it into the P182's 5.25 driave bays with the rails it stands proud by about 10mm when the rail is in the locking slot, I have the drive on the last set of holes possible there's no way I can get it any closer to the back of the drive, anyone had this before?Sounds like the something could be shorting out. When you first power on the PC, is the graphics fan staying on full speed permanently, or does it calm down? (Not all cards power up like a maniac to begin with).Hi peeps,
First message in the forum but I have been lurking for a while.
Anyway I bought a P182 last week but have a few issues you maye be able to help with,
1. I stripped my mobo etc out of my old case and transferred it across but no image on my screen, all the fans worked and the HD started to spin but that was it nothing else no beeps, no graphics nada. I have ordered a cheapo PCIx graphics card to check if mine died in the transfer, anyone had this happen before?
I have this same thing with my DVD drive, cant get it to go the whole way in, I cant find any way of getting it to go further. However, I found it to be quite useful to access the drive, since the 'overhang' on the top of the door is quite big.2. I bought an Asus DRW-2014L1T 20x DVD±RW SATA Dual Layer Lightscribe ReWriter from OCUK of course (typical it's on 1 week special now) when I tried t fit it into the P182's 5.25 driave bays with the rails it stands proud by about 10mm when the rail is in the locking slot, I have the drive on the last set of holes possible there's no way I can get it any closer to the back of the drive, anyone had this before?
Hope one of you can help,
Martin
anyone noticed how much dust gets pulled inside the front door lol.
Does this case support MATX boards?
