Thanks for the quick reply. But if you dont add a speaker, how do you find out if the comp is running the right way. How do you go about using your own speakers to listen for the beep..
Well if you loop the line out from the onboard audio to the line in on your soundcard won't it feed the beep to the pc speaker?
Anyway you don't really need the PC speaker connected anyway
these days mobos will tell you onscreen what is wrong if anything si wrong, My P35 P5KC for example does just that and never once thought of attaching a speaker!
