I am using the INTEL HD Audio connector from the case connected to my motherboard which features a choice of AC97 or HD Audio, I intend to install a Creative X-Fi soon which also features aHD Audio Header. I'm not sure if any sound cards feature an AC97 connector but most motherboard do.Can someone give me some advice on the front panel audio connector?
It's the cable that says AC97 or HD Audio, not USB 2.0.Anybody know the easiest way to determine which cable is the front audio?
I guess you should reveal which soundcard you intend to use and find out what audio header it has?
I had the Audigy SE and it doesn't have the front header connector, I bought a Xonar for £64 with delivery and this one does, not sure about any others sorry.I'm going to put in a cheapy SB Audigy thing.
Probably be easier to get some cable ties and move the cables out of the way?
Ah cheers, at a glance I didn't notice they had labels, got the front audio working with my Xonar now, thanks.
Thanks Jihad, do you have any idea what the white header on the card is for?
