What kind of power supply do you have? If the PSU isn't powerful enough you could run into issues while overclocking GPUs or CPUs; the 5850 needs at least a 500W decent PSU to function properly.
Mine arrived today. Installed, took a few moments for anything to appear on screen, I thought 'uh oh..' but then it posted. Installed cat 11.4 drivers.
No issues so far.
Hey Merlin5 I'll bear that in mind when I install mine. When you say a few moments, how long would you say that was?
I've got a Corsair 450W, which according to everywhere I've looked at is more than adequate. Corsair state this as suitable for the whole 5800 series. There's no issue there, it's just that going on the reviews these cards aren't great overclockers. Let's hope for a working Trixx...
Most say they aren't so great overclockers, but I got mine easily to 825/1225 stable so far; I was probably very lucky. All in all, apart from being lucky/unlucky, I strongly believe that decent PSUs are very important for overclocking (stable voltages) and also good ventilated cases --and let's hope for a working version of Trixx, at last!
What temps are everyone getting with these on load in Furmark?
Mine hit 72 after 15 minutes full on, is this about right or too hot?
(This was at 775/1150)
Even 825/1225 could be considered a "poor" overclock when compared to the original HD5850. As long as the original had voltage tweak well over 950Mhz was attainable quite easily.
In its own right though a 100MHz boost on the core is pretty good.
Look what I found
http://www.sapphiretech.com/ssc/TriXX/
Trixx v4.01 is out and it specifically notes that it fixes the overvolt problem with these cards. Report back people if it helps.
