I'm weighing up if I could feasibly do something like this for my next build, I have a few questions if you have a moment Mr Biffa -
What's the layout for standoffs like on these? Is it possible to use an ATX / or E-ATX motherboard tray and just add additional support on the end or do you need to re-drill the holes? I'm considering the possibility of hacking out the tray from an old ATX case and have it open in the shed or getting a Silverstone TJ07 motherboard tray and house it in a blank 5U box.
Also you mentioned you can build up the cpus gradually, is it the same with the memory?
Lastly, are there any particular requirements of the PSU? Would my current one be able to handle it?
http://www.akasa.co.uk/update.php?t...plies&type_sub=Performance&model=AK-PSS100FGM
Cheers
Cheers
