[TW]Fox;22045345 said:A used good engine from a crashed car is surely the best solution?
One here:
Hondas are notoriously hard to rebuild unfortunately.![]()
No3 rod big end bearing has spun inside rod housing
- Spun bearing the crankshaft has suffered excess wear/damage to the journal
- The remaining big end bearings have been inspected and all show signs of “pick up/oil starvation”
- The main bearings on journals 2,3 and 4 (1 and 5 have not been looked at)– same here, pick up/wear through oil starvation.
- No3 big end bearing which spun has shed lots of material through the motor so all oil passageways will need to be thoroughly cleaned out and quite possibly a new oil pump required (won’t know until pump removed and stripped for inspection of gears).
- Possible damage to the top of the piston and underside of cylinder head – head can normally be cleaned up but piston would need thorough inspection.
A replacement crankshaft and conrod are the instant requirements for repair/rebuild along with gaskets and bearings etc of course but other items such as piston, oil pump would not be known until full strip is performed.
*As a side note, the first thing we did was check the oil level – halfway between min and max was showing on the dipstick. This is not enough for track work (We always recommend running a good 3-5mm over the max mark for peace of mind) especially at places like Castle Combe with it’s right/left/right through the first chicane and old paddock bend. This is the highest likelihood area of the track for oil surge/starvation issues.
IDK? Would be unlucky even if he didn't tbh, plenty of Hondas rock it around tracks without problems.
It was baffled by him on 21/03/12, it was confirmed by him as a good idea should it ever see track work. There was a Civic with the same engine running flat out all day on much sticker rubber than I had with no issues.
If it was a pickup issues due to a pump blockage would that then cause it to burn it's oil in the amount it did? Or does it then come back to it died because there wasn't enough oil because it had burnt it all.
No, I suspect another spun bearing tbh.
I just mentioned oil pick up as a theoretical problem, which it would be, but I'm hoping there wasn't bits of crap floating around your sump beforehand in any event.
I expect the counter argument to be, has the car performed correctly since November last year, and when was it last serviced and by who?
I'd put it down the experience and move on. Don't drag it out as it will stress you out and get messy.
It's not the end of the world losing a few K. Millions of people do it every year on new cars!
New engine is 2k
