BEING UPDATED
Test Results
Aurora
RRP £15.00
ETA **/**/20011
Not to be used with impingement water cooling blocks. Only to be used with fast flow blocks. This is a wide effect liquid using much larger particles than Aurora +.
EK WB
Supreme LT AMD Acetal AMR3 -
PASS
Supreme HF (restriction plate removed) -
PASS
Supreme HF (restriction plate installed) -
FAIL
XSPC
RASA water block -
PASS
RS240 -
PASS
X20 750 Pump & Reservoir combo -
FAIL
Single Slot Pump & Reservoir combo -
FAIL
Laing DDC 200ml Reservoir Pump Top : Plexi -
PASS
Single 5.25″ Bay Reservoir -
PASS -=Out standing effect's=-
Duel 5.25″ Bay Reservoir -
Watercooling
Heat Killer (With Restriction Plate) -
FAIL
Heat Killer (Without Restriction Plate) -
PASS
Phobya
DC12-400 12 Volt Pump -
PASS
DC12-800 12 Volt Pump -
PASS very hight flow rate - looks like liquid is on acid .....
Balancer 150 Black Nickel -
S.1366 / 1156 Water Block -
PASS
G-Changer 240 -
PASS
Swiftech
Apogee XTL
(will not be testing)
Apogee XT Extreme
Koolance
Koolance CPU-370 (with small restriction plate)
FAIL
Koolance CPU-370 (restriction plate removed.)
PASS
Laing
DDC 10 watt (working) ( better using the 18watt though)
DDC 18 Watt (working)
D5 (not tested)
Aurora +
RRP £17.00
ETA **/**/2011
Aurora + Has a much smaller particle size. Works really well with 1/2" tubing showing excellent effects..
EK WB
Supreme HF (restriction plate installed) :
PASS
XSPC
RASA water block
RS240
FAIL
FAIL
PASS
PASS
PASS
Watercooling
PASS
Phobya
PASS
PASS
PASS
PASS
G-Changer 240
Swiftech
Apogee XTL (will not be testing)
Apogee XT Extreme (will not be testing)
Koolance
Koolance CPU-370 (with out restriction plate)
Koolance CPU-370 (with restriction plate)
PASS
Laing
DDC 10 watt
PASS
DDC 18 Watt
PASS
D5
Update 2
Aurora base colours
Usage : For none Impingement water cooling blocks, Do not use with inbuilt low pressure pumps that are inside reservoirs.
Clear / Blue
Clear / Red
Clear / Silver
Clear / Gold
Aurora + base colours
Usage : For Impingement water cooling blocks, Do not use with inbuilt low pressure pumps that are inside reservoirs.
Clear / Blue
Clear / Red
Clear / Silver
Clear / Gold
Below Blue / Silver
Above Gold / Red
