not if you drank more tea/coffeeVeNT said:in wich case you'ed be hydrated
j00ni said:caffeine, being a diruetic would actually make the urine lighter whilst simultaneously dehydrating
I hate the kidney
did me well in my first year of exams though.Aye. Also the reason pee will commonly be clear the morning after a drinking binge. You're dehydrated (commonly the main cause of the hangover) but its still pretty clear because alcohol is also a diuretic. They're both fairly weak ones though IIRC.j00ni said:caffeine, being a diruetic would actually make the urine lighter whilst simultaneously dehydrating
rather not, i have enough of that with the project I'm doing atm on the renal unitMikol said:who will be the first to start talking about vasopressin/adh... you or me?I hate the kidney
j00ni said:rather not, i have enough of that with the project I'm doing atm on the renal unit![]()
The helpful grades then indicate if you should be drinking more or if you're there or thereabouts.
Drinking more waterJon Frost said:awsome![]()
That's some nice English there.Back of the pee-o-meter said:....see which colour most closely resembles the colour of you wee
Scuzi said:I now drink ~4 litres of water a day and I feel a hell of a lot better for it. If my urine isn't as clear as a fresh mountain stream I knock back about a litre of water![]()
ic1male said:But isn't that going from one extreme to the other? Aren't you in danger of "drowning" yourself in you drink too much water - diluting the chemicals in your blood and causing an imbalance?
Only if you're not getting enough sodiumic1male said:But isn't that going from one extreme to the other? Aren't you in danger of "drowning" yourself in you drink too much water - diluting the chemicals in your blood and causing an imbalance?
Scuzi said:4 litres a day isn't too much, in fact it can be not enough on really hot days like we had over the weekend there. If I was drinking over 6 or 8 litres a day then I'd maybe start to worry but 4 litres over a day is about right. I just drink whenever I'm thirsty.
Mikol said:Highlighted the last bit. You got it spot on. You should never force your self to drink more water than your body requires. You will know when you're dehydrated, only because of the colour of your urine but when you're thirsty. Keep a glass of water beside you and when you feel like you need a drink, drink that.
Although for Scott Salisbury, this doesn't appear to be the case![]()
Scott Salisbury said:I rarely drink anything and I'm never thirsty
Which means I should just make myself drink as I know I have to. 4 litres seems so much![]()
