I'll let you know how I get on then![]()
Your loss if you want to ignore 60 years of sports science
Point taken!Your loss if you want to ignore 60 years of sports science
Snow has curtailed my running this week. Got up this morning but it’s really icy under the snow so not worth the risk.
Might have to go for gym treadmill run tomorrow if it doesn’t clear up.
Went to my review appointment for the broken elbow and they didn't seem that fussed on whether I ran or not. So off for a run, tomorrow, better get ready with all those kudos on Strava![]()
Hi all
Other than the obvious - distance, speed and heart rate what would you say is the next most important stat thats useful for running?
Further to my watch thread https://forums.overclockers.co.uk/t...ng-me-out-please-help.18844951/#post-32476915 I'm trying to work out if all the additional statistics that are available via HRM-Run provides are really required or not.
If the following are important then I have no choice but to go for the forerunner as the vivo does not offer connectivity to HRM-Run:
- Cadence — number of steps per minute
- Vertical oscillation — degree of ‘bounce’ in your running motion; displays the vertical motion of your torso, measured in centimeters for each step
- Ground contact time — amount of time in each step that you spend on the ground while running; measured in milliseconds
- Ground contact time balance — displays the left/right balance of your ground contact time while running (displays a percentage); for example, 53.2 with an arrow pointing left or right
- Stride length — length of your stride from 1 footfall to the next; measured in meters
- Vertical ratio — ratio of vertical oscillation to stride length (displays a percentage); a lower number typically indicates better running form
I assume both watches offer cadence without the HRM-Run strap anyway. Are any of the others above really needed?!
Cadence is the only useful metric that can be trained, has an impact on performance, and can predict injury risk. Even then, it is not critical and if you have a good cadence then you can basically ignore it. I was worried my cadence was low so got a foothold, turns out I'm bang on 180 when running on the flat so now totally ignore it.
The other values have some relevance to performance but you can't really train them. A lower vertical oscillation is more efficient for example, but nothing much you can do to lower this explicitly. Instead, as always, the more you run the more efficient you get and the better these values will be.
Run a high volume of easy miles and all these other metrics will improve slowly.
Also my Apple Watch only used 35% battery tracking the run, heart rate and playing music. That suggests it could cope for me on a marathon without needing my phone.![]()
Can someone recommend a pair of running trainers, decent ones.
According to the Manchester Marathon website it suggests they’re ok with headphones providing your not “racing” by which I take that to be someone hoping to be well placed for a prize.
Not someone who’s just happy to finish!
Not sure I could complete it without some form of distraction!
