Just a heads up mate, Nvidia do sell other cards that don't cost £1000![]()
Show me an nvidia card that can beat the £530 295x2? It doesn't exist and for that price its a bargain considering its still top dog in the performance stakes dual gpu or not.
At minimum fps where it really matters both the Titan X and 980 beat it in a lot of games actually.
If you're looking at max fps in games that scale well then the 295x2 looks better.
Average fps is where it matters
Average makes no difference to me if it's a few fps slower. If minimums however dip 10fps lower that is quite noticeable.
So it glitches in most tests then
If that were the case we would see the same minimums on all cards.
Yes if you play benchmarks, no if you play games. Smooth gaming with most frames rendered at close to avg speeds > stuttery gaming with high peaks and deep lows, even if the latter had nominally higher avgs.
Hate to break it to you but i've seen plenty of reviews in the past that pointed to minimums as being nothing more than loading kicking in or streaming from hard drives. Its also deceiving as they can be nothing more than momentary and barely perceptible to the user yet graphs can make them appear as if they impacted the game far more than they actually did. On reviews and min fps, ive seen some show the 295x2 get low minimum fps and others not agreeing with that, yet as is usually the case on this forum people will pick and choose to suit their agenda.
Playing benchmarks , thats a cute concept.
The reviews were carried out on the same rig, if the minimums were caused by anything other than the card we would see it on all cards tested.
Fact is the minimums on the review I saw looked consistent and from my own testing having owned both the TX doesn't drop as low.
And yet other reviews don't agree with your findings, yet some will. So who are you meant to believe exactly?
I'll believe my own testing then.
Who are you siding with? Let me guess the ones that show the card you own favorably.
Hate to take a massive dump on your little theory but i really couldn't give a flying **** what is in my pc be it amd or nvidia. Its for running games, last i checked i didn't sign up to be a cheerleader for whatever card happens to be in my machine, apparently some on here did though. I got the 295x2 because at the price it was offered for theres nothing that can beat it. Simple as that.
Well 2 seperate 290's are cheaper but I'll let that pass.
It was also the reason I bought it at the time till I realised some games the minimums were as good as one 290x.
What little theory? I didn't say you preferred one brand it's just you seem rather defensive about people questioning certain aspects of the 295x2's performance.
So will you see the 390x as a flop then if it doesn't beat the 295x2 on average fps?
Because it's surely going to be more expensive than you can get a 295x2 for on release.
