Do you still own shares in AMD?
And several others, including Intel and Nvidia.
You paid part of my dividend, what do you think about that?
You paid part of my dividend, what do you think about that?![]()
AMD's drivers have been flawless as far as the AMD fan boys are concerned although they're always happy to admit that they weren't very good in the past - work that one out.
That does ring true, thinking about it
I've had my fair share of problems with both teams drivers, if you've updated and you get some problems...roll back? Latest Nvidia drivers really ****ed up BF4 for me and a few other people. I'm on some older ones currently, will see how they fair later tonight.
Both sides have issues with Drivers otherwise every driver release wouldn't have a "Changes and Fixed issues" section in their release notes - e.g. Nvidia 347.09 fixes 6 issues, but they still have around 20 open issues listed.
He was trying to use a 290 on Mac when it wasn't even supported.
pebcak
Do you think that by shouting around that every single AMD GPU you have had in the last X number of years had Driver Issues will convince people that it is as you say an issue with AMD Drivers?
It doesn't.
If you have had 6 of the same car and have taken every one back because the engine blew up; you tell people that's proof that there is a problem with the car, people will laugh at you and say, "Nah mate, its you"
It does quite the opposite.
That makes sense, Apple make their own Drivers and then lock them solid to whatever hardware its supposed to be running.
Using an Apple Driver to run something its not designed for was never going to workout well.
That is an example of pebcak.
AMD Do "NOT" Recommend you use there Driver removal software..
This is what AMD recommend
http://support.amd.com/en-us/kb-articles/Pages/GPU57RemoveOldGraphicsDrivers.aspx
That software is only there for someone upgrading from AMD motherboard to an Intel Motherboard and do NOT wish to re-install Windows..
People need to understand that software isn't a GPU un-installer like for example DDU!
So right away there is one mistake you have made.
I don't even use DDU anymore.
I did not make a mistake, I did what they told me to do. IE - before you install the Mantle driver you must run their app that cleans out any previous drivers as they will not work with Mantle.
I ran their app, cleaned out the rig alright. Cleaned it so well that when I rebooted my entire system was not usable.
They're likely to have changed it now but it still happened.
Twice.
Well seeing you using Intel I find that hard to believe... The software you talking about Removes AMD's Chipset Drivers, USB and GPU.. The first two your System doesn't even have installed to begin with..
Last do you have a link? To what AMD say about remove driver before installing with Mantle?
Quite funny how Mantle as worked for me without using such software..
