Post your hard drive benchmarks!
On average how big are games/applications/windows vista64 OS files? Only reason I ask is because im trying different strip sizes and im trying to find out which one is the quickest and best suited for my needs. . .
Im currenly experimenting with a 16k strip.
Seagate 1TB Drive.
4xWD250gb (IDE) Been running for 3.5 years in Music server.
One drive failed and had to be replaced with:
1 Seagate 1TB Drive to replace them all
Currently running on an old Asus A7N8X-E (SATA1) Windows XP (AMD XP 2400)
Also I have a Asrock 939Dual
With a 300gb Maxtor
Hope the stats are usefull to someone ;-)
There's nothing wrong with what's normally the minimum speed - the speed at the 100% mark. There is, however, something using the disk on a regular basis which is causing some I/O contention and hence the regular dips in the graph.
2x36GB Raptors WD SATA I 16MB Cache W.D. Raptors in RAID 0
2x500GB AAKS WD SATA II 16MB Cache drives in RAID 1 (<-with an external backup solution - I don't even know why have bought two of these and mirrored them. I might destroy the array and sell one)..
edit - could anybody confirm if this is roughly what I should be getting? I am using an Asus AM2 sct M2N-E motherboard, and using an onboard RAID controller.
That's very slow mate, have you got the write back cache enabled?
What strip size you using?
Yes I was going to say thats Raptor raid is slow, obv aint a PCI bus with 200 burst though.
Hmm...I think for a little bit both drives were being accessed - shall I run them again with everything turned off?
Edit - I ran both tests again and came up with almost identical results.
