I have finally got my two 32GB Samsung SLC based SSDs on a RAID setup.
So nice bet thats snappy right there !!!!![]()
Mick-1965 - Are they the Seagate ST3250410AS? Mine are on ICH9 but the difference should not be that great and your graph is very flat too ... see the post below (there are others with even more performence on here!).
http://forums.overclockers.co.uk/showpost.php?p=11000315&postcount=568
Thanks for tip. Just installed Intel Matrix manager 8.2 and it automatically enabled the writeback cache on the drives.
Pablo1870@h*x*s) said:I would caution that people research for versions of their Hardrive options, that ACTUALLY implement the NCQ feature. The difference between desktop (non-raid only) implemented NCQ and drives that will only allow u to use them in raid, has actually been measured. The difference can be 50% in speed or more when multitaking.
The samsung 1TB and the seagate 7200.11'sand the WD 640mb versions are the only ones i am aware of that currently do this.
http://forums.storagereview.net/inde...howtopic=26965
and
http://forums.storagereview.net/inde...howtopic=26006
desktop use is multi instance access,
Have you taken off the little jumper off your hd? Only reason I ask is because your burst speed should be a lot higher. Take it off and run another benchmark.
