Should be possible, though it'd be difficult to build something that would match an existing finish.this would be an idea method to raise my tv so my centre can fit in front of it! i would just have to put a shelf underneath the bottom as my av unit has a glass top and wouldnt appreciate metal legs on it..is this doable? the tv is a 46 plasma and obviously fairly heavy
Strength wise, my stand weighs well over 20Kg without anything on it. Add in all the hi-fi and it's in the ballpark of 60kg+. I can only just lift it from a side and it's possible to slide it on carpet with some effort. There isn't a problem with stability, though it will wobble slightly if shoved. The shelves were strong enough to support my weight.
