I will have project (pond and garden) that will need a Mitre/Chop saw
accuracy and straightness is needed hence not using my existing 4.5" angle grinder.
The pond walls will be made of 7N dense concrete blocks 215mm wide, 100mm high and 440mm long. The corners of the pond are at non-90 angles so I need something that can cut concrete with a dry cut/diamond blade. The garden will also have some wood too so if it's easy enough to switch out the blade for a wood one - that's good. Dust extractor (shop vacuum) connection is a must (and I may put it in a popup toilet tent to control the additional dust. The majority of cuts will be across the 215x100 face and being able to cut at angles would be good.
I've seen the Rage 2 chop saw YT with concrete and that seems to make a decent cut at speed but only cuts 90deg as far as I could see. The Rage 3 Mitre + concrete blade seems a lot slower.
So thoughts? Options?
