Old and just priced crap I guessDEWALT DCF892N-XJ
DEWALT DCF899N
Wait, the 899 is brushless too and more powerful. So why is the 892 more expensive?!
DEWALT DCF899N
I’d go non official with ryobi. I had a ryobi drill with two batteries and they both died even though they were stored with charge.I've received a Ryobi reciprocating saw as an Xmas present, but with no battery or charger. There's a huge price difference between the official and non official batteries for the Ryobi range. Does anyone have any experience of using the cheaper ones? Is there much difference in quality/performance?
DEWALT DCF892N-XJ
DEWALT DCF899N
Possibly too much of a beast!Wow the 900HN is a beast
Yeh breaks sockets lolPossibly too much of a beast!
screw fix is awesome. Well priced items they have over therehttps://www.screwfix.com/p/bosch-gs...olpack-cordless-flexi-click-screwdriver/755pg This is the same kit by the looks of things for £20 less.
Jigsaw should do the trickI have a load of timber skirtings to install. Do I need a bench mitre saw to do the mitres, scarfs and bevels? If so what would people recommend?
Will it be ok to mount it onto a folding workmate or does it need a different platform?
Really? For corner mitres? The skirting is profiled so it's going to be difficult to keep the saw flat on the board even if the blade is set to an angle. I'd be worried the jigsaw would give uneven lines and the two pieces wouldn't mate properly.Jigsaw should do the trick
Ahh right ok.Really? For corner mitres? The skirting is profiled so it's going to be difficult to keep the saw flat on the board even if the blade is set to an angle. I'd be worried the jigsaw would give uneven lines and the two pieces wouldn't mate properly.
that is so useful. I've watched a handful of youtube videos but nothing as clear as that. Ok, it might be doable with a jig saw after all. Fantastic. All I need to buy is a sliding bevel
