Precision Boost Overdrive How Much Over Max Boost You Have
3700x pbo +100MHz with noctua d15s ( btw it is 4.4 on the box)
Q. Why limit it to +100? It goes up to +200 doesn't it?
My logic is +200 and the CPU will boost to what ever it can up to +200. No?
I've left everything on auto regardless.. but this was before I got my 3700x.
Theoretically it would boost higher under better cooling condition. Pbo is basically just increasing breathing space for it to boost higher (like sliders in afterburner).
Oh so can you increase PBO in Ryzen master itself?
I did a manual OC changed all the 3800 to 4400 and it insta crashed on prime 95. So I'm guessing that's not the way to do it since then I just put it on PBO and leave everything on auto.
Just looking through some of the posts here.
I haven't checked my bios so I'm not sure what the options are but are you just setting PBO +100/200 to get those boost overclocks. Is it as simple as that?
3600X here on an Asus x570 TUF.
No matter what I do in the bios it won't boost past 4367mhz which I've only seen once.
Usually all core settle at 4265mhz in cinebench or a game, even single core cinebench but then drop to 3.8-4.1 after.
Is it true that an all core overclock is not really doing the speed & is micro throttling beyond the scope of monitoring software?
Regularly see 4.525 and 4.550 on my 3800X, obviously in very short bursts.
Really?? That's awfully high. Higher infact than AMDs stated "MAX". That no one really actually gets.
Well I would not be satisifed if I was either one of you guys.Both your CPU are underperforming but there will be a fix from AMD someday.
Mine 3600X does 4525Mhz like in the videos posted.I am satisfied.Forgot smiley face :D
Ryzen 7 3800X -4500 Max Boost on the box + up to 200Mhz=4700Mhz
Ryzen 7 3700X -4400 Max Boost on the box + up to 200Mhz=4600Mhz
Ryzen 7 3600X -4400 Max Boost on the box + up to 200Mhz=4600Mhz
I haven't added any boost overclock yet - but I think I'll have a go. Is that literally all you did was enable the over ride and add the numbers? Why only 125Mhz and not 200Mhz? Or was 200Mhz not stable?
If it howers above 4.1 in allcore tasks (cinebench etc) - it is pbo at work , by the looks of it (mine increases from 4.0 -4.1 to 4.175-4.3 GHz ), still for those tasks multiplier oc (ccx or allcore) will defo do better (with unsafe voltage most likely). During typical whole day use in real life would show: 4 cores done 4.425; 2 - 4.45; 1-4.5; 1 - 4.4 as max hit speed. Personally after first few days playing, benching and testing my Division 2 bench would show few % better results with pbo vs 4375 MHz allcore oc, so that when i told myself : "Get your sweaty palms of that marvelous thing" :D .
p.s: Ram ocking is safer and more time consuming anyways :p .
Nah, don't you worry I'm very satisfied. I know my CPU is performing fine and inline with 99% of people's 3700ks.
4.6ghz stock is not a realistic goal. Basically noo is getting that so don't be daft.
This is a question I still need answered. Why not just add +200?
Well my Motherboard I can select up to 500Mhz and several modes of automatic overclocking by AMD algorithms which do everything 100% stable.
EG: This screenshot is with
Enhanced Mode 4 in BIOS
AGESA AMD ComboPI1.0.0.3
AMD Ryzen™ Power Saver Plan
5 CCX Boosted to 4400Mhz
1 CCX Boosted to 4450Mhz and all cores boosted above max boost written on the box of 4400Mhz.This applies to Light loads/90% games/Cinebench single test with boost to 4525Mhz
Results
BIOS selections modes
Interesting you can be satisfied all you want.
My Rzen 3600 is boosting to 4374 on single core operations. It will only clock at 4049 when all cores are under heavy load. Am I right in thinking then that PBO works best for individual cores but not as well as a manual overclock for all core performance?
Reg overclocking memory.
Is it true the infinity fabric, memory controller & memory frequency (pre doubled) all have to match 1:1:1.
As in 3600 memory = 1800Mhz on all.
If the memory goes over 3600 then a performance hit is incurred unless perhaps the infinity fabric frequency is matched elsewhere?
As far as I understand the maximum 1:1 ration of memory to IF is up to 3733MHz (may be 3800MHz). However after this value the IF switches to a 1:2 divider so you can configure your ram higher but your IF is halved.
You can set it to whatever you want really,as far as I understand. It is a form of overclocking which can disable/bypass limits and can void warranty like anything else .
Precision Boost Overdrive/Precision Boost 2/Max CPU Boost Override allows an AMD Ryzen processor algorithm to increase clock speeds and voltages when the CPU has electrical, thermal, and/or utilization headroom to spare and can/will boost to maximum overclock for the CPU. In other words: if the processor’s analysis of its own environment indicates that it can safely go faster, it can/will ,also there is always safeguards in place.
Each CPU of 3xxx has a hard limit but Actual BIOS revisions/Chipset Drivers and AMD /Microsoft power plans have an influence on how much voltage and clock boost there can/will be for the CPU.
With 3600X both hit a limit of Max boost of 4525Mhz and not full 4600Mhz which is 4400Mhz on the box + 125Mhz,maybe if a had a better Motherboard/cooling my max could be higher up to 4600Mhz. Hope this help ,I could have copied the AMD stuff but I just wrote what I thought how it works.
Depends on CPU up to 1900Mhz(3800Mhz)
After that point Memory clock / Infinity Fabric /Memory Controller will work 1:1:2
EG:
2100(4200Mhz) memory Clock
1900(3800Mhz)Infinity Fabric
1049(2100Mhz)Memory Controller
If you leave IF clock on Auto, it will switch to 1:2 at anything over 1866 MHz (3733 MT/s). Quite a few people seem to be able to set it manually to 1900 MHz though and retain the 1:1 ratio.
