Project Android
Messiah khan :eek: i have just read through all the thread up till this point im very very impressed you are certainly one creative talented guy :cool:. As previously posted you really should get in touch with some computer magazines for a spread on your project case :). Any more updates?
Cheers guys(and ladies), as always I appreciate the support. :)
Thank you. I will get in touch with magazines and websites once the end is in sight. I will be pimping the project as much as possible. I however don't want to try promoting it too soon as interest might fall if I take too long and I don't want any time constraints. As for updates.. you'll have to wait until the weekend probably. I normally only work on it on the weekends as im too tired on weekdays. The next update will no doubt be more pistons, then fixing the ribs.
messiah khan said:
And the next update is.... now! ;)
YAY. Looking good! :D You are learning quite a few skills doing this project which must be quite cool too.
messiah khan said:
That all until next weekend proabably.
OMG!
I think
A; your insane
B; your a genius
Its a fine line so they say.
Just read through the thread, good luck with the finishing touches this is quite a project. Bookmarked.
Just looked through the entire thread and well ... what can one say !!!
That is one mighty fine bit of work you're carrying out there!
Can't wait to see the finished article :cool:
Good luck with it this weekend !!
Updates ... :p
been a silent follower of this thread for a while now. It looks amazing to say the least. A bit OTT on the attention to detail but that just makes it better.
What was wrong with the previous idea of using the camera stand as the neck? I seem to have missed it. It jumped from the camera stand to the home made pistons.
Any new updates?
Any new updates?
Hello silent follower. :) If you think the attention to detail is OTT now, just wait until I start adding detail and purely decorative stuff. :D You havent missed anything btw. The pistons are as well as the camera stands. The camera stand is so that i have a poisitionable ball and socket joints in the middle, wi the pistons around the outside, simply to make it look better. If you look at the following pic, you can see the sort of thing im aiming for;
Might be a little tricky to get it looking that good, but i'll try my hardest. I havent got any updates at the moment. The weekend just gone I was making the other 3 pistons, and also reworking the one I had made already as I wasn't 100% happy with it. Ive managed to join the pistons together without using any epoxy glue now, and it look far better. :)
Probably not tbh. Im seriously considering leaving the painting until next year. I really don't want the cold to damage the paint finish, and the garage is too big to heat up while painting.
yea that makes sense like, after all the hard work that you have put in, the last thing you want to see is the paint crack or something. well do you expect to get all the work done, besides the paint job before next year.
Not sure. I'll try and do everything I can do before next year anyway. There are bound do be some parts that I want to do after the painting though. Some of hte wiring/electronics etc. But other than that, yeah im likely to get most of it done.
I'd love to get some high res pics of the vid so I could check the detail out, like the stuff inside the neck/arms etc as its kinda hard to see it there.
-I-Am-Great- said:
oh ok one more question. got any big ideas for your next project, i don't know if you can really surpass this one lol
Well im going to be building my main rig probably around the start of next year. Its going to be nowhere near as outlandish as this one, but should still be cool all the same. Its basically going to be a customised v2000 with Phase cooling, water cooling etc. Should be fun to do(if not a little expensive) For the next major mod though, i'd like to do something with flat surfaces and right angles ;) Had thought of some sort of ITX case.
@ Vent... The music vid(not high res, but better than nothing);
and the making of;
yeah I watched the making of too, some close ups of the frame would realy help, pitty its at 640x480
