Project: Angel
I can answer that for you, Im also using a Zalman fan controller and the same Enermax fans. They just fit on as they are with the extra part of the fan plug just poking over the edge. :)
Just had some very good news guys. Enermax have very kindly offered to add to the sponsorship and are providing me with a whole lot of fans and the Revolution 85+ 850w PSU.
Here are the fans which will suit the build perfectly:
and the PSU which OC3D reviewed recently:
http://www.overclock3d.net/reviews.php?/power_supply/5-way_high-end_1kw_psu_round-up/5
Exciting times indeed:)
Hey just wondering how you got them to sponser you?
I need a lot of fans fo rmy build lol
Just get in touch with the company. Quite a few people managed to get sponsored by manufacturers or shops. Helps if you've done a few decent builds in the past to show your not just after free things, its actually going to have effort put into it. Also probably have to agree to post build logs on 4 or 5 different sites to make sure theyre products are seen by lots of people
fantastic, so if i get to about half way through my build and then contact them (it's not a normal build, it's extremly modded) then it might be worth contacting them ?
thanks
Yea, dont see why not. Show them your progress, and any build logs youve got going on any forums and they may well be intrested :)
right thanks, that's great I will get further into my build post some logs (when i decide which way to go on cooling) and then hopefully make some contats :)
thanks again for your help
