Once again, sorry for the (very) long break between updating this project. Sorry to both my sponsors and just as importantly, the members of this forum who have been so kind with their comments thus far. I'm not the type to give up on anything and intend to complete this rig if it kills me! Anyway, I've finally sorted most of whats been going on in my life so it's time to get this project back on track.
You may remember that I fitted two Thermochill PA 120.3's to the front panel and those more astute among you may also remember that there is actually room for four PA 120.3's. Well I went and did it, I fitted four
Having a bit of spare time on my hands this week, I sprayed up the remaining two rads and fitted them to the case complete with 6 enermax twisters and colour coded fan grills:
The first one was fitted above the other two but due to clearance issues come tubing time, this one was not fitted with a shroud. The front fans on the rads attached to the case will be working as intakes, sucking cold air from outside the case over the rads.
The fourth rad is positioned low down to the rear of the case. While this rad will not recieve clean cold air (sucking air from inside the case, acting as an exhaust) it should still prove cool enough to keep the chipset cool....and it would have been rude not to make use of the space for another rad
Starting to look a little cramped in the bottom half of the case so I think that'll do for the cooling capacity of the 'Angel'.
Next up - Pump mounts.
