In a fairly unsurprising move, the Bentley decided that she didn't want to come home just yet. The mechanic who's been working on her was test driving and making sure nothing else was wrong....when something else went wrong. The car is now sporting a broken Woodruff key in one of the rear hubs.
Now, this wouldn't disable a car with a limited slip differential because you'd still have drive to one side. Alright, not ideal but at least he could move it around and get it back onto his lift inside the workshop. And given that this is a Bentley Mulsanne S, which was a bloody expensive car back in the day, you'd expect the manufacturer to fit such a device. After all, they increase safety, and winter usability, and improve handling, and....well, you can see where this is going. Of course Bentley used open differentials on these cars. Why would they spend money on a proper diff'?
 End result is that all the power that the rebuilt gearbox is sending out is being used to spin one side of the diff uselessly.
At this point I'm pondering....well, several things:
- One of the rear hubs has been apart before, when that previous mechanic had the car for over half a year stuck in his workshop. What am I bet that the key has broken on that hub?
- Maybe that key has been weak for a while, and the rebuilt gearbox is transmitting rather more power and torque to the back?
- If point 2 is correct, then once it's all back together I suspect this car will have some actual speed to go with all the noise that it makes at WOT.
- If someone invented a time machine, I could use it to go back and beat the entire R-R/Bentley design team senseless with their own slide rules. Special attention would have course be paid to the **** who did the rear window demist.
Mechanic is checking to see if he's got a key that'll fit, if he has and can get it all nailed together
again today and test it (no way in hell are we taking it back if it's just going to break down again straight away) then I'll go pick it up later. If not, it'll have to be next week.
