Popped to the garage this morning with Gary. She's running a hell of a lot better - the timing is still a little off, but she at least revs up without shaking herself into a million pieces and the tappety sound on cylinder A3 has gone.
Humour us with the price of the pads please.
We-e-e-e-ell nuts.
I don't think the ignition timing is dead-on perfect on the engine. But I'm fairly sure it's close - because the old girl fires off the line like the proverbial excrement off the garden implement used to move the aforementioned excrement around
I forgot to say with the latest work update that a rubber donut in the propshaft had torn itself to bits (apparently the ****s at Crewe were too cheap to put proper UJs in anything that wasn't turbocharged *sigh*) and had to be replaced. That's been sorted....but I'm now wondering if the vibration I'm feeling is partly to do with the driveline, and either the prop is out of balance or something else is not quite aligned. Because the worst of the vibration is when moving off from a halt - in Park, rev'ing it up is pretty much as smooth as it should be. In Drive, moving off from a standstill there's a fairly wicked vibration.
R-R/Bentley technical documents are currently my bed time reading![]()
Well the guibo is good enough for BMWsThe purpose of these is to make take off smoother and less clunky.
Have you had the propshaft balanced or machined at all?
Sad way to end the thread, but at least you guys gave it a good shot!![]()
Have you not considered just setting yourself up as a Bentley specialist?![]()
