Gosh, what a surprise! It's still running like ****, at least at anything approaching WOT. I've had the injectors out of cylinders three and four on the drivers side (A) bank. Gary blew air through them with a compressor. The one from cylinder A3 had a fairly weird spray pattern, so today I swapped the A3 and A4 injectors.
And yet A3 is still dead - if you pull the HT lead off while the engine is running, the engine note doesn't change at all. So to summarise - cylinder A3 dead, cylinder A3's injector suspect, move suspect injector to different cylinder, cylinder A3 still dead.
What. The. Hemorrhaging. ****?
***edit***
It's getting a bit bad now. I can generally stay patient with cars misbehaving, but I have to admit to having properly lost my **** over the last two days. Full on raging, throwing tools around, bear-with-sore-head deal. I once said on here that I was extremely bored by the Crewe factory idea of 'good enough' - I'm now beyond 'bored' and into 'white-hot furious' territory.
